Will rev 3 cams fit straight in rev 1 head?
Im rebuilding my head (reseating valves, a slight skim, and check valve clearance) to refresh my rev 1 , researched a bit and read that the rev 3 n/a cams are more aggressive. Now if i just replace the cams with the rev 3 ones - will it make an improvement, or will i require more mods to see anything noticeable?
thanks
[Mk2] [NA] Will rev 3 n/a cams fit straight into rev 1 head?
Re: [Mk2] [NA] Will rev 3 n/a cams fit straight into rev 1 head?
This is a toughey as I've never done it... it reality, you'd need the rev 3 cam gears to go with it or adjustable ones to carry out adjustments to yield more power / setup correctly.
The duration maybe the same with a greater lift on the NA cam, but the phase angle maybe different .. ie. On the rev 1/2 turbos.. the exhaust cams are the same in duration and lift as the rev 3 turbos.. but the lift begins 6 degrees later due to the cam gears... hence the above recommendation.
Personally.. for the hassle in reshimming it all and little benefits.. I wouldn't bother doing it. You'd get more from fitting adjustable cam gears and working with the cam timing.
i cant say about stock but i know there's been plenty of issue with aftermarket camshafts that are meant to fit all rev heads fouling on rev 1 & 2s
O/T but I'm waiting on a reply to a PM I sent you jason_pmr2
