[Mk2] [Turbo] t3 adaptor
does any1 know where i can get an adaptor /flange to fit a t3 turbo?
Re: [Mk2] [Turbo] t3 adaptor
ATS do one, and delivery from the states aint too bad.
http://www.atsracing.net/CT26%20to%20T3 ... dapter.htm
XSpower do one that doesnt fit.
If you do get it, you need to take about an inch of length out of it, and then move the wastegate flange. (If you have a rev 3)
The ATS one fits a charm.
- IMOC Committee
I currently have one for sale on a rev2 manifold with the wastegate flange welded into the mani if that's any use?
http://www.imoc.co.uk/forums/viewtopic.php?t=123520
mark239 wrote:XSpower do one that doesnt fit. If you do get it, you need to take about an inch of length out of it, and then move the wastegate flange.
I had to do this...
Anyone will tell you in the know that cast iron is notoriously hard to weld though, if you're thinking of doing the same thing.
I've still got it knocking around the garage somewhere..
