hi
finally decided I want a new intercooler so i can up the boost a little
just basically want to ask if anybody knows if there is a real difference in the so called big brands (greddy, berk etc) and the xs intercoolers off ebay going for 100- 150 quid?
are you just paying £££'s for the expensive names? or are the ebay ones a waste of money?
thanks
ive got an xs power intercooler and ive had no problems. they are welded and some do crack, but they are also 500 quid cheaper.
they will both do a good job, better than the stock one.
if you could get a second hand one then get it, but the xs one seems fine for moderate mods.
thanks for all the replies and thats what I wanted to hear lol
not going for too much power and I can weld so shouldnt be a problem
if they are flimsy brackets i could knock some better ones up at work
ive got the xs power on mine and so far so good.
my guess as to why intercoolers snap there mounts is because your probs useing hard pipes , standard hoses ie not very flexible ones. and soft (old) engine mounts.
maybe a change to hump hoses and stiffer engine mounts would help,.
ie... the flex in the engine added to the unfexability in the hosses and joins. snap the brackets off.
redmr89 wrote:ive got the xs power on mine and so far so good.
they snap because they are "floating" intercoolers, basically thoses brackets hold the whole unit and there is a lot of flex etc.., the stock one has a few mounting points
i have a greddy SMIC at the moment but had an XS power one in my old rev 2 the difference between the 2 is definately noticable! but thats not to say the XS one is bad...not at all!!! brackets did snap on my xs one and the pipes did blow off and to be honest didnt seat very well but with a little welding all was good. just to clarify i bought my 2 with a greddy SMIC i wouldnt fork out for one to expensive for the amount of difference
