I have a set of HSD coilovers which i'll be fitting soon, i was wondering if anyone has encountered same problem as i will have as regards the brake lines.
The HSD coilovers dont appear to have anywhere to clip the brake line to like on a standard shock.
Has anyone encountered this problem if so what did you do as it can't be good to have to brake lines unsecure.
Alan
[Mk2] [Generic] Fitting Coilovers - brake line advise please
Re: [Mk2] [Generic] Fitting Coilovers - brake line advise please
cable tie should do the job wont be the prettiest but you could probably hide it quite easily
Yeah i thought cable tie not sure if m.o.t testing would approve thou.
Would be best with a nice secure bracket, guess i'll have to fabricate something to work better but cable ties look like the easy option for a quick fix.
I got the HSD's I cable tied mine and it went straight through its MOT
ive got hsd coilovers and ive just fitted my do-luck braided hoses.
do the hoses have to be attached to the body as well as the shock to pass the mot????
can some body post some pics of there braided hoses and hsds to show how theyve arranged the front to stop them interfering with the wheel etc???
thanks
thanks
