Techy question re Mk1 MAP sensor
LimeyMk1
Post by LimeyMk1 »
Has anyone out there (Nadir or Jeremy? :pray: ) got a list of the different voltages that the ECU will see at different vacuum readings?
I'm considering using the stock MK1 MAP sensor on my Mk1.6 but need the spec for the ECU. It's either that or shell out £50 on a Marelli 03/04 MAP sensor which the ECU already has the data for. :-k
Part No. is 89420-17020 I think.
crazybrightman
Re: Techy question re Mk1 MAP sensor
Post by crazybrightman »
i did some tests on mk1 a and b map sensors a while back. now ill have to double check but the mk1b map sensor reads from vaccum to 3/4psi positive boost. working between 0.3 and 4.7v but ill have to double check hope that helps.
4agte on the way
LimeyMk1
Post by LimeyMk1 »
Cheers Neil, what I need is a number of mV readings at different pressures so that I can plot a graph and from the equation of the line work out the specific entries for my ECU.
I've done this with the Mk1 air temp sensor and got y=-43.819x + 4435 where y=mV and x=air temp. I need to add a few more readings to the graph as I only have points between 19 and 50 degrees C. I'll be doing the same with the water temp sensor from the MZ. So far the readings have had a linear trend which has simplified things somewhat. :lol:
vashy
Post by vashy »
Vacuum, Voltage drop
100mmHg, 0.3 - 0.5V
200mmHg, 0.7-0.9V
300mmHg, 1.1-1.3
400mmHg, 1.5-1.7
500mmHg, 1.9-2.1
Source: 4AGE repair manual
getting close then 8)
. . 6 . 7 . 8
5 . . . . i . . 9
LimeyMk1
Post by LimeyMk1 »
Cheers John. :thumleft: Will stick those numbers in the ECU and see what happens. :pray:
Not too far to go now. :mrgreen:
LimeyMk1
Post by LimeyMk1 »
Big ol' bump for those that are interested I've fitted a Vacuum gauge (101-90kPa) to my MAP sensor and got some pretty accurate readings of the voltage seen by the ECU.
I may try to get a gauge with a wider range at some point but for the moment the conversion equation is y=30.349x + 511.49 where y=mV seen for a vacuum of x (kPa).
Pic of the graph plotted:
Edit: forgot to adjust the barometric pressure at the time so ignore the equation on the graph.
vashy
Post by vashy »
:tumbleweed:
...only joking Chris hoho!
well I'm interested :study: wow. bet you weren't expecting it to be quite that accurate! and it's pretty arrow straight, you should be able to extrapolate the full range from that pretty safely. hmmm I wonder how barometric pressure compensation works then..?
. . 6 . 7 . 8
5 . . . . i . . 9
