I would like to know where to take a live from the engine bay fuse box to power my chargecooler pump, i would like the power to come on with the ignition and turn off when i remove the key.
so which power supply should i use in the fuse box and do i need to change the fuse to a slightly bigger one,
thanks
I'm not sure what the cc pump on my GT4 draws but it'll be a few amps anyway. I would have thought you want to tap into the main supply going into the fuse box (comes in in 2 cables and onto 2 separate m5(?) terminals under a rubber cap near the front of the fuse box). I'd run it through a relay to switch it on/off -depends whether you want to find a switched live somewhere local or run a cable up through into the cabin to find a switched live.
You would need to fit a fuse for the pump and one for whatever you're going to turn the relay on/off with (think I used a 2A fuse for the relay on my lid fan kit).
correct, in the engine bay fuse box, any of the black/red wires is a switched ignition source. Just make sure you use a fuse. There is a constant power source there as well under a red rubber cover.
