Does anyone know if there is such a thing as a dump valve that does not make the pssst sound? The dump valve on my rev2 Mk2 turbo is very loud and I am hoping to change it for one that is silent or at least one that is quieter.
Andrew
DNOS808 wrote:After compression by the turbo the air is over 100 degrees I believe.
DNOS808 wrote:Thank you all for your replies.![]()
I have a standard Toyota recirculating valve but I am reluctant to go down the recirculating route becauseI am a bit worried about the temperature of the air going into the engine.
I have heard that this high temp makes the engine more prone to detonation.
Does any one know if recirculating increases the charge temperature and if so does that increase the chances of detonation?
Andrew
