Just wondering will they still sit as low as they should with no other suspension mods???
[Mk2] [Generic] Just got some TEIN S springs......
Re: [Mk2] [Generic] Just got some TEIN S springs......
I seem to remember a 38mm drop front and 39mm drop rear... So yes, it'll be lower than standard.
I'll hunt for the source of the info..
Here you go..
http://www.tein.co.uk/installation_manu ... 89-98.html
Top one... I was very close!! 37mm and 38mm!!
I think the answer is yes. The car will sit the same height with the springs and any damper combo. Whether the existing dampers will have enough damping force is another thing.
R.
R.
-:[KM]:- wrote:I seem to remember a 38mm drop front and 39mm drop rear... So yes, it'll be lower than standard.
Hi,Lol what i meant is that although they say a drop of 37-38mm will i need other mods suspension wise to drop the car or will the springs be enough?.
Cheers for the info though bud!
HighwayStar wrote:I think the answer is yes. The car will sit the same height with the springs and any damper combo. Whether the existing dampers will have enough damping force is another thing.
R.
Hi,What do you mean by damping force being enough ??
They'll be fine!
Get 'em on, it's a couple (or three) hours work and get some pics up!!
Check droplinks and susp. tops while you're there.
