Hi all,
I have some Supercharger lights from the USA, I've done the necessary wiring and bulb change to make one of the reversing lights act as a rear fog light... problem is that the light looks VERY pink, and not particularly bright! I think this might be down to the really quite thick white plastic lens (and possibly my eBay special 10LED red brake light - but this does shine quite bright red when not in the lens.).
Has anyone with Supercharger lights successfully managed an MOT passing rear fog light?
Cheers,
Nick
Supercharger light fog conversion
Re: Supercharger light fog conversion
I went with a bolt on one underneath the bumper, (though i put it on the N/S which it failed on - it has to be on O/S)
Could be an interesting one to convert a reversing lamp though - hadnt thought of that!
Make sure you have it on the O/S one though!
I have heard of the reverse lamp being used before, but to get it bright enough you just need a higher wattage lamp IIRC.
A quality light gel/filter (the type used in theatre & concert lighting) can also be used on the inside of the cover to get a better red colour, but you can only buy the gels from reputable sellers. The cheapo mobile disco & Maplin type places may sell the gels, but they are poor quality and will fade/melt easily.
This is a company I used to use professionally:
http://www.leefilters.com/lighting/prod ... C0C1B557F/
2 things:
1. Fog guard lights have a reflector in them to better directionalise the beam - it may be an idea to go to a scrappers, get one and cut it down to suit.
2. I've used sweety wrappers in the past to colour bulb outputs - like the strawberry ones in a Roses tin
When I did the conversion on my car to SC lights, I used the empty red reflecter on the O/S and used the UK standard o/s light loom which already has the fog light built in(this plugs straight in and requires minnor modification to fit) I then made a hole into the back of the relector area and used the silver backing from a uk fog light to fit in behind fog light, Its not been to the MOT man yet as I only done it a few months ago but cant see it being an issue as its brighter than the side lights.
Basically the fog light is in the same place as a uk car but it looks like a standard SC light from the outside
Mk1b White T-bar SC 1987, Mk1b White coupe Jan90, Mk1b White coupe Jan90 (spares), Mk1b Mica blue T-bar Mar90, Mk1b Mica blue T-bar,full climate control,Jan90, 5 mk1's
Thanks for the answers guys!
I might go ahead and try modding the inside of my light cluster like oukie mentions, as this way I get to keep my second reversing light too! Now to see if I still have those UK clusters....
i converted one of the reverse lamps on my old MR2 ages ago, its so easy, swap one connector over and thats it done. anyway, it passed 2 MOT's like that, it just had a red bulb in there. im not sure there is a requirement for brightness, so long as its red and works. if your MOT tester is that picky then go somewhere else!!
Update
Hi all, a quick update for you...
I went the way of the Oukie and hand crafted (bodged!) my supercharger light unit and the reflecty fog light bit from a UK unit together.
This works like a dream, and I passed my MOT today!
Cheers for all your comments
Been meaning to do this for 'years' on my SC conversion I always just fitted the ugly dangly fog light for MOT day... took it off when I came home but obviously would be good to have one fitted in AND save the 2nd reverse light which always looks better than one
Also I have a spare set of N/A rear lights so will try the method above, should be no problem!
Ive got to say I did it that way just because I did't want the dangly light .
My MOT man thought it was very good
Hello,
I posted some pics up over on the mk1 club if anyone is interested...
www.mr2mk1club.com/forum/viewtopic.php?f=25&t=2179
Nice one, going to have a go at this myself.
-Alan
-Alan
