If anyone can help me with these I would be most gratedful! I just bought a whole instument cluster with 160mph clocks and delimitter already attached to it which I have fitted myself.
The original speedo on the old cluster had packed up and since fitting this one I still have the same problem.
So obviously it is something else and nothing to do with the cluster? The cables are all connected so what else could this be? Heard it mentioned about a sensor somewhere? What should I be looking for and where? Anyone else had this Problem? Secondly, when my lights are on shouldnt there be a yellow light on the dash? The blue
`full beam` light comes on when I switch them on, and also the fogs work but no light appears on the dash? Any ideas? Thanks in advance for any help! Cheers.
Dan.
(Car is 1990 Revision 1 GT Turbo)
