Hey put a post for you on mr2mk1club:
I've fitted several 4E-FTEs, never on a MR2 but I know the ECU
(all variants 2 plug, 3 plug, AT, MT) like the palm of my hand.
Have modded those engines too.
We had a Starlet in Malta running 12.6 at the strip
(and it wasn't set up for that
- but set for hill climbs, so more handling then pure straight line speed and a useable torque range as opposed to narrow top end).
Amazing engines- but becoming rare.
This was my first 4E-FTE install, was 16 at the time and new so little about ECUs back then.
http://www.kyokudoracing.com/car_ndr.html
5E-FTHE/FTE
(Using the Toyota Sera/Cynos/Paseo block and internals) route is supposedly more powerful, but less revy
(same broke
- longer stroke
- means pistons have to travel a longer linear distance in the same, means more stresses on the components).
I personally like sticking to the 4E-FTE there is so much you can do on a 4E-FTE setup it is really sick.
Also head to Toyotagtturbo.com but caution.
loads of idiots there now.
I used to be technical mod and then became super mod but as of about 2 years ago.
I just left, too many xxxx now.
most of the old community doesn't go there anymore in fact.
UKstartletclub is not too bad.
