[Mk2] [Turbo] nur spec flexi damaged
decided to investigate the cause of my noisy exhaust today. At first i thought it was coming from a poorly fitted down pipe, but after closer inspection, it appears that there is a blow out from the flexi section of my nur spec. Can i buy a new flexi section, and if so where from? or can it be fixed? cheers
Re: [Mk2] [Turbo] nur spec flexi damaged
you can get them on ebay and Im guessing most places that make exhausts eg Powerflow exhausts will have them
I noticed most Nur Specs seem to blow do they not come with any warranty? Try contacting them and see before you chop it up
only came with 12 month warranty. i'll email them about a replacement part and then i'll shop around. cheers
i went to powerflow when my flexi started blowing on my nurspec. They supplied and welded ina new flexi to high quality for £80 HTH
