hey
just a few questions regarding brakes if I may!!
will rev2 calipers and discs fit straight onto a rev1 without modification of a bracket or anything?
If I it the uprated rev2 calipers and discs to the front of the car and left the back (until purchased and fitted) will this have a major negative effect and cause braking imbalance?
and last one are there any fitting guides ! im sure ive seen one but ive been searching to no avail
Thanks in advance guys!
[Mk2] [Turbo] Brake upgrades
"If in doubt, go Flat out"
Re: [Mk2] [Turbo] Brake upgrades
rev2 brakes will fit straight onto your hubs, you wont need to add anything else, one thing you will need to do is bend the dust shields by hand to accept the larger discs
if you want just the front calipers and discs then PM me, I have a front set of rev3 used calipers for sale
cheers
cheers
