Hi all,
I picked up a Rev 3 sw20 turbo last week. When going over bumps/ small pot holes/ or poorly surfaced roads the rear drivers side clatters fairly loud. Just had a chap I know check out the spension struts, springs, engine mount and all other spension lower arm, arb joints etc and all doesnt really have any play in it. Also checked for wheel wobble - no problem. We noticed the car is fitted with rear tie bars that connect to the bottom arm's - is this a normal setup on a MR2 or an after market mod?This 'may' be the issue as a ickle bit of play...if not anyone else had a similar issue and know what it may be?
Cheers.
[Mk2] [Turbo] Clattering from rear
Re: [Mk2] [Turbo] Clattering from rear
could be quite a few things but main suspect is usually the droplinks
other things are ball joint, rear arb bushes, top mount, spring not fitted correctly etc
the tie bar sounds normal
i find the best way to diagnose a fault like this (as you cant sometimes replicate the sound by pulling/pushing on the components) is to get somebody in the boot (not with it closed obviously ), get under the car and place your hand on each component while the person jumps up and down in the boot with varying force
hth
Jay
hth
Jay
lol...thought you were gonna suggest driving around with someone in the boot for a second as said droplinks and ball joints sound favourite to me
Thanks Jay I'll put the wife in the boot then Cheers for your help.
bu88er! tried the jumping up and down in the boat...nothing. Changed droplinks yesterday + was doing discs and pads all round wheels fine, rear struts and springs fine and all torqued up...the show goes on. Got a balljoint and tie bars to check next
anti roll bar bushes then maybe....you need to have it up on a ramp and swing off em to see if there is any play in there..although I would expect to feel the lack of stiffness in the cars movement.
Turbos sometimes have problems with the intermediate drive shaft bearing. The bearing support bracket has a rubber tipped bolt to hold this in place. The rubber degrades over time allowing the outer race to move in the housing.
see:
http://www.mr2turbo.info/pics/driveshaft.html
This might be the cause since you're able to be so precise as to where the noise is found. That said, I'd expect there to be a clatter over smooth roads as well.
Worth a look.
see:
Worth a look.
cheers guys. Guna do a coolant change this Sat + have a replacement ARB and bushes so pop that on. Not sure how to fit the balljoint I have so expect I'll have to get a garage to do that if the clatter is still there.
Regards Turbo..could well be something in the engine bay for sure hard to tell when driving. I have a bumpy section at the end of my road so prob get a pal to walk along side the car with engine bay up and listen to where its coming from - engine or suspension.
Tie bar solved this one! Car had aftermarket rear tie bars fitted, not as good as the OEM ones it seems. Thanks to Jay for the part.
tim355 wrote:Thanks Jay I'll put the wife in the boot then Cheers for your help.
I too had this it turned out to be drop links, now I get a different noise which I am hoping is my worn springs (I just got some Teins delivered today), otherwise its bushes/arbs next.
