Hello
After going through several fragile innovate LC-1's (even on their forums there seem to be a lot of failures, particularly from HT interference) I needed to find a reliable controller.
I came upon these on my travels, and have used in 3 cars and 1 bike so far with great results, stability - and most importantly - they are ruggedised so can be mounted under the car, or externally (on the bike for example)
http://wbo2.com/2j/default.htm
I got mine for £120 + postage on ebay with sensor.
The software is easy to use, and has plenty of features, and the calibration button is on the unit - as is the status led. Small things that to me make a huge difference.
Theyre open source, and there is pretty good support.
Thumbs up from me anyway.
[Mk2] [Turbo] techedge wbo2 controller - highly recommended
Re: [Mk2] [Turbo] techedge wbo2 controller - highly recommended
I've got an older version of this which i built DIY- very good bit of kit, well priced and works well too. Recomended!
