[Mk2] [NA] tapping ????
i have a tapping noise from the top of the engine gets louder and faster with the revs any ideas???
Not So Fast But Just As Furious =]
Re: [Mk2] [NA] tapping ????
I'm having the same problem, anyone got any idea's? Thanks.
worn shims? would sound something like tappets but the mr2 doesnt have tappets .
shims are basicly spacers that sit ontop of the valves (hence why the noise is at the top of the engine) as the cam rotates and touches the valve caps (sat on top of the shims) they get worn slightly over time and to make sure you have the correct gap between the cam and the valve cap you need to replace the shims with the correct gague. if you dont, eventualy the valves wont fully open becasue shims are not thick enough for the cams to push them that far.
im sure there are some other suggestions too
Could be the exhaust manifold blowing too, makes a tappy sound also.
phipck wrote:worn shims? would sound something like tappets but the mr2 doesnt have tappets .
i have the same problem too, is this a fix i can perform myself and how exspensive will it be please?
IF and i mean IF its the shims it isnt a costly job, but it is a very involved job. the simplest way to explain is for you to read this article, its the same process for n/a and turbo although there are minor differences in the strip down
http://www.lovehorsepower.com/MR2_Docs/ ... stment.htm
i would investigate the correct clearence for the shims on the n/a before starting as they might be different from the turbo
Just had this problem. The no.2 lead wasn't pushed on top of the plug properly so it was earthing to the head
Sounded exactly as you described...try taking the leads out and putting them back in firmly.
It does sound like the shims
