JDM holder+13x7 inch front number plate - how did you attach yours?
without screwing it on? I'm looking to basically glue it on, I assume any Evostick type product will hold it well enough?
Re: JDM holder+13x7 inch front number plate - how did you attach yours?
lots of places that sell plates online, also sell VERY strong double sided padded tape...
i used that with mine.
i think drilling/screwing on plates looks awful!!!
this stuff is available from WHSmith and the like, most even say "can use for number plates"
also alot quicker to do than measuring drill holes out.
sorry, unless your talking about the holder onto the car, and not the plate onto the holder???
nah jim, the number plate onto the holder - the holder is screwed into the bumper so its fine. I'm just a little nervous as I now have a double line front plate and I know it's going to overhang the JDM holder. Don't want the fecker to come off and break something on it's way to the scenery.
I missed a trick with getting the tape along with the number plates
ive used that tape stuff since i got my first mr2 5 years ago.
never EVER had an issue with the tape in all that time. holds solid as the day you put it on.
cheers jim, got a linky? Ebay is full of stuff lol
i honestly couldnt pick anything in particular tbh.
when i got my plates made it came with the tape already....
am sure anything that says its good for number plates will be fine dude.
my rear numberplate is held on with a foam double sided tape i got (dont laugh) poundland and is very strong indeed held my plate for the last year and a half.
I used aryldite (spelling?) works a treat!
I used the double sided tape before and a brief foray to the exiting side of 140 relieved me of the plate!!!
Glue it my friend
Glue it my friend
double sided foam tape from halfrauds - the thicker of the two on offer.
it works really well. just make sure you line it up straight...
alan -drop by mine and il give u some -u only need a couple of strips cos it sticks like xxxx to a blanket ,i use it and its abs solid.dont buy a roll just for a couple of bits
jim55 wrote:alan -drop by mine and il give u some -u only need a couple of strips cos it sticks like xxxx to a blanket ,i use it and its abs solid.dont buy a roll just for a couple of bits
cheers Jim, appreciate it. You about at the weekend though I may go for glue?
Alex - yeah I know the stuff, I was going to get some Evostick or Bostick but knowing me I'd glue myself to the holder / plate
pretty much all day sun il b here ,il pm my contact details and btw i wouldnt use glue ,foam d/s tape can b removed with b a heat gun ,glue is a bit more hassle if u ever need it off
