Moo, I fitted a cusco strut brace and the refitted the stock as well
- its pretty simple to do
- just shorten the stock brace slightly redrill the holes and gently bend the arms back and bolt it down.
You may have to put a slight
"dent" in the back of the right hand arm to clear the electrical multi block
( right hand- with you standing at the front of the car looking at the windscreen.
I dont have the car at the moment but when I get it back I will post you up a couple of pictures.
As for Ultra racing they have their own website if you do a search and the guy that runs it is called Elson Tong
When I bought mine they did a deal on the shipping as I bought the under wing braces and the chassis brace together.
They were cheaper to buy direct fron there than on ebay but you will find that you have to pay import duty on them
- the courier company they use will phone up as soon as they arrive in the U.K.
and tell you what that is
- they wont deliver until its paid.
I have read some where on here of some fitting problems with the chassis under brace
- mine went straight on with only a bit of filing of one of the holes
(the problem was an extra amount of powder coating in that area which made the hole a little smaller) and minimal stress so I may have got lucky or some one else may have had a bad one- I will see if I can find the link.
