Hi
I have a Mk1b that has had a full respray and I need to put the plastic trim strips that run down the sides of the car back on. My local body shop has a double sided tape that has a foam layer that is used for this job. unfortunatly the tape is much thicker than the original tape and so will cause the strips to have a gap between them and the bodywork. Does any one know where to source a thinner tape suitable for the job?
Regards
Andrew
Trim Strip Tape - Where to buy?
Re: Trim Strip Tape - Where to buy?
have a look around homebase,b&q etc they have a few different types.
i used one from there when i fitted the strips back on mine.
You'll find that the type used for sticking lino down with is best: it has a sort of woven cloth base, rather than fibres...?
It sticks like s**t to a blanket! B+Q may have some, but CarpetRight, etc will DEFO have the stuff......
Some kind chap on here recommended VHB tape (Very High bonding?) and kindly sent me a little to do what I needed. It is the poodles noodles and I highly recommend it, car resto companies do it I think, google has the answer!
