how do i check if i have LSD?
just wondering how i can check if my car has limited slip diff?
Re: how do i check if i have LSD?
why do you want to know? will you change it if it hasn't?
the code is on the vin plate in the front, post what you see.
I was told the fun way to check this is give it some beans and burn some rubber then get out and check your freshly left tyre marks. If you have 2 marks then you have LSD, 1 mark then No LSD
Have fun
Have fun
Jack the back of the car up so both rear wheels are off the ground. Turn one of the rear wheels by hand, if the other rotates in the same direction, you have an LSD.
The above doesnt work however for purely mechanical diffs, but does work for viscous and clutch plate type diffs.
or look at the vin plate
still does'nt mean its the original box though..!!dansREV2turbo wrote:or look at the vin plate
easiest and simplest way is as said above, go to a car park somewhere and light em up
you'll know for sure then.
Stushine wrote:lol,
is it only certain models that las LSD?
rev 1/2 it was optional extra . rev 3 comes as standard . (on tubbys)
Could also have an aftermarket one fitted. God knows what them crazy guys over in japan have done to our cars before shipping them over lol
carlos9999 wrote:still does'nt mean its the original box though..!!dansREV2turbo wrote:or look at the vin plate
even with the stock diff in you can still light both rear tyres up in a straight line
TOTB 2010 Rwd top speed, 1/4 and shootout winner.
10.7@142 on R888 street tyres, 10.3@134mph on slicks,
9's on slicks to come, with a clean full throttle pass! Goal of 0-150mph in a 1/4 of a mile....
just do what some intelligent man has already suggested; jack it up, turn a wheel,if the other turns with it, there you go, you are a lucky owner, lol.
you'd know if it had an lsd fitted by the feel of it, if you cant tell then there is no point knowing imo.
StuRobinson88 wrote:just do what some intelligent man has already suggested; jack it up, turn a wheel,if the other turns with it, there you go, you are a lucky owner, lol.
That doesn't work with all types of LSD though.
JohnnyC wrote:StuRobinson88 wrote:just do what some intelligent man has already suggested; jack it up, turn a wheel,if the other turns with it, there you go, you are a lucky owner, lol.
Which is what I said above, it doesn't work for purely mechanical, i.e. helical diffs, like torsen and quaife ATB style diffs.
take it apart...
VERY simple to find out if it is LSD or not just spin up in a straight line in the wet if back end kicks out to left or right then no lsd if it goes straight then it has LSD lol well thats how i tested it lol with my rev2 i had and my rev3 i have now lol
not on a roundabout you cant.. but a fair point you made there..!!
give it some gas on a bend/roundabout and look for the 2 tyre marks..
not on rounderbout in a straight line
sorry dude that wasnt a reply to you, i forgo to add the quote
rhamps wrote:VERY simple to find out if it is LSD or not just spin up in a straight line in the wet if back end kicks out to left or right then no lsd if it goes straight then it has LSD lol well thats how i tested it lol with my rev2 i had and my rev3 i have now lol
I have an aftermarket diff in and my back end steps out a little when I spin up but it keeps the car in a straight line
