My name is Joey, I'm 19 Years old and I'm from the United States
It is in the process of being built as we speak.
Here are my modifications
3sgte block
Head:
Turbo:
Clutch: Clutch Masters Stage 3
Exhaust:
Fuel: Stock fuel
Here is a picture of my car
![Image](http://i133.photobucket.com/albums/q79/Joemanchill/IMG_1590.jpg)
Also, I have a 2000 Celica Gt-S
![Image](http://i133.photobucket.com/albums/q79/Joemanchill/IMG_1596.jpg)
![Image](http://i133.photobucket.com/albums/q79/Joemanchill/IMG_1662.jpg)
Now the Help I need is; I'm doing the timing belt, I'm sure I have the Cam timing correct
Exhaust Cam
![Image](http://i133.photobucket.com/albums/q79/Joemanchill/IMG_1814.jpg)
Intake Cam
![Image](http://i133.photobucket.com/albums/q79/Joemanchill/IMG_1815.jpg)
Now; the only thing I'm unsure of is the crank timing.
![Image](http://i133.photobucket.com/albums/q79/Joemanchill/IMG_1818.jpg)
Is that the correct timing for the crank gear; If it helps, Piston 1 and 4 seem all the way at the top of the stroke.
Thanks you all in advance!
