where on earth do i start getting these to legal limits??
cars a 1998 rev5 mr2 turbo.
its does have a phoenix power CAT
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/photo-33.jpg)
Dangerous wrote:pm rowland im sure he knows a way round this..
by taking your passenger seat out!!.
jimGTS wrote:Checked commander.![]()
And the o2 f/b control is off.Just like the boost control kit.
It's got jap symbols next to these options.So I have to asume the o2 one means off because I don't have the boost kit and that is the same symbol.
jimGTS wrote:£15.
They guessed really as never been asked just to do an emissions test.
Could I not just adjust the fuel with the commander just for emissions, really need a wideband? Woud the o2 sensor option need to be on for the test as well as lean the car out?
Is this really a datalogic job? Or can be done all with the commander?
Kongaroo wrote:
Right so if O2 feedback is off then the car will have been running whatever the base fuel map is set to for those load cells- ie.
there will be no automatic correction back to lambda by the Power FC.
So it sounds like your base fuel map is indeed too rich in those cells representing the car when stationary between 2500 to 3000RPM.
jimGTS wrote:Ok cool.Cheers.
I understand that all now, LOL.
So werth me just driving down to the garage with normal maps.Then when it's off for mot
(the car needs to be driven down the road to the mot center from Kent car craft who I'm using), just quickly pop it to o2 sensor enabled, put boost to wastegate pressure and maybe even lower the rev limit to 5k so it's not boost on to and from the mot place.
Then when I pick it, pop the o2 thing back off and away I go.
If it still fails(I can't get Ryan this week, and mots this week), I'll just have to get him down for the retest and tweak it then.
Dam annoying, cause surely all these 1000hp supras and skylines still need to pass emissions and they'll have more mental fueling then me.
