Can you give me jj justy a basic run on figures i should expect to see on the fc when underload for my setup??
At 1.2 bar
???!! On a night
- 320/330 bhp
!! Day 310bhp
Its the torque improvements that your car will have gained.
You'll get more with efficiency improvements
cooler air, higher lift
/ longer duration cams
Mine made 425bhp
@ 1.3 bar
couple of penquines were watching at the time though it was that cold
turbo was a large scale one.
.laggy and all at the top
Your would have annilated it around the tight twisty roads.
open road
- boost for boost.
I would have squeezed past.
i knew you would be on jj, man of all knowledge bud
Just a head full of crap Dave
Water temps thermostatically controlled, shouldn't really move much from 82 degrees circa.
only if you've stopped a hot engine, gone back to it a few mins later.
you'll find your air temps will be on the up as well.
I'm sick of my MAT sensor
( manifold air temp
) sat in traffic
it just heat soaks and the way I've got th epower fc set up, when it see's high intake temps, it retards the ignition.
!!! Rubbish.
Looking to relocate it when i pull my finger out to the exit pipe of the intercooler
You'll notice the temps will fall when you start driving, especially when you part spool the turbo as its pushing cooler air in
Whats this 1.2 bar lark
