[Mk2] [Turbo] can I use the standard bolts from stock/cat elbow onto downpipe
lee.w
Post by lee.w »
basically without having to fork out more money on bolts , can I still use the original bolts from the stock elbow/cat onto a aftermarket downpipe , or is best to buy new bolts again.
dansREV2turbo
Re: [Mk2] [Turbo] can I use the standard bolts from stock/cat elbow onto downpipe
Post by dansREV2turbo »
i cant see why not mate....
.. 8-[ expects someone to jump on me!
-:[KM]:-
Post by -:[KM]:- »
Get new ones. The amount of turbos I've seen come loose. They're single use and are only about 4 quid each.
If you're gonna re-use them, make sure you tighten them good...
-:[KM]:-
Post by -:[KM]:- »
The stock cat has studs in the bottom flange too, so you'll need some bolts there anyway. Not from Toyota mind...
dansREV2turbo
what size thread are the turbo-elbow bolts?
lee.w
Post by lee.w »
dansREV2turbo wrote:what size thread are the turbo-elbow bolts?
have no idea , I'm having a turbo back system fitted soon so I thought I might be able to use the same bolts that are used on the stock elbow/cat to use with my downpipe . :-k
lee.w
Post by lee.w »
one more thing , does anyone know where you attach the downpipe support bracket :?
-:[KM]:-
Post by -:[KM]:- »
lee.w wrote:I thought I might be able to use the same bolts that are used on the stock elbow/cat to use with my downpipe . :-k
The only bolts you will be able to re-use are the two for the rear hangers & one for the support bracket... The standard DP has STUDS at the lower flange!!!
lee.w wrote:one more thing , does anyone know where you attach the downpipe support bracket :?
One of the old cat bracket bosses on the block, it's just above the sump IIRC...
Oh, and IIRC the stud threads for the turbo flange (the 6, or 7 studs) are an odd thread. 8x1.25 seems to spring to mind.. :-k Or was it 10x1.25...?
8x1.25 seems a regular size on reflection...
Driftlimits Performance
IMOC Affiliated Company
it's 10x1.25
And the cat support bracket goes on the same fitting as the bracket on the oil return line! You knew that Keith! :D
Just remove the bolt, prise up the oil line bracket v.carefully and slip the bracket between that and the block.
-:[KM]:-
Post by -:[KM]:- »
Skywalker wrote:it's 10x1.25
#-o Thought it was...
Skywalker wrote:And the cat support bracket goes on the same fitting as the bracket on the oil return line! You knew that Keith! :D
It's been that long since I've played with a standard set-up.. :oops: It's all a very distant memory.. :mrgreen:
