my car may soon be going to 3s to have a full turbo rev3 conversion
when i get the car back what are the main things that are going to need to be changed ie brakes etc
or can i just run the car straight out of the garage with no hidden extra needed
cheers
Turbo engine in a n/a
Re: Turbo engine in a n/a
i say tyres
brake is same i think
also driving habits
possible suspension,
also driving habits
Not really anything you would HAVE to do as the were little in the way of differences between the turbo and na version of the car (ie ran same suspension, brakes, etc)
On any car you would be advised to at least check the suspension & brakes, wheel alignment to make sure the are ok. I would deffo think about replacing the brakes for the bigger rev2 onwards sets if you've got a rev 1.
Spending some money on improving the standard suspension set up is a worthwhile investment unless you already have done it. A nice set of yellow billies with some eibach pro-kit springs and TRD top mounts is a popular choice, and if you add ploy bushes and new anti roll bars it would transform the handling of the car to match the new performance you have.
The difference between an na and turbo in power is quite a lot so careful with that heavy right foot, try to drive smoothly and turn that boost down in the rain.
Ask James if your unsure of anything or want some advice
cheers for the replys guys
well i have 500/600 to play with after conversion so im thinking a few lil engines toys,i have tein springs and strut braces,d2's are lil pricey for me right now lol,
also im thinking of new drilled and grooved disks with green stuff pads with new brake fluid etc.
new tyres are a defo with allingment
is a ebc or mbc nessecary...?
what bhp is achievable with standard turbo and internals etc
cheers
steve
cheers
steve
an mbc would only be needed to increase boost, the standard rev3 was 240bhp so you should have around that figure too start. a healthy rev3 with bolt ons can be 300bhp read the articles in the knowledge base for futher info and advice on that
"If in doubt, go Flat out"
