Hi Pacman,
The only two that are stuck on are the small one between the front wheel and door
(does have a small plastic plug though, and the door strips.
Rest are bolted in place from behind.
You can get to the rear ones from the boot and rear wheelwell, vent ones are difficult, need to remove the plastic surround near the seat belt and you will see a round rubber plug, remove that and put a
deep![](./images/smilies/spacer.gif)
10mm socket in the hole to find the nut.
There's another bolt in the rear wheelwell and a popper.
The very front have two bolts which you can either reach by removing the weather shields from the underneath, or the headlights.
Please note that all the bolts in the wheelwells will probably shear off as you undo them.
I fortuantely had a spare set of strips and had to chop some of the spare thin n shaped metal bolt holders off and weld them the new strips.
Hope it helps
Marc
