Gents,
I noticed yesterday that my nearside headlight does not rise to full height and that it pops up a little higher before it dips when I switch the lights off.
The lifting mechanism obviously requires adjustment. Any idea how this is done? There is only one motor, so I guess the adjustment is down to nuts and bolts?
Also, is this an easy DIY task?
Peter C
Headlight lifting mechanism - adjustment?
Re: Headlight lifting mechanism - adjustment?
My left one does this ,i though it was the motor so i changed it and it still did same but after spending hours trying to adjust it i gave up.
To adjust theres a nut holding an arm attached to motor, just undo and turn arm a little bit and re tighten.
open your frunk, look down by where the light fitting is you will see like a little red or black nob twist that and you will see the headlight adjust up and down
Thanks Skipp, I'll try that!
