looks like i should set it up retarded, then go looking for someone to map it for me
Ryan at 2Bartuning can help, he can advise the nearest rolling road and set it up there.
but agreed, set it up in a retard state.
My dizzy's practically cocked right over.
How do I make sure that the dizzy is in any posi
Anti-clockwise
= Retarded
Clockwise
= Advanced
Engines that have been mapped, then the dizzys pulled off must be marked at set back up in its
"mapped" position.
Failing that, stick it in a retarded state for a retune.
how do I stop the PFC messing with the ig timing so I can find where it's set
I've never done it or needed too.
I've just taken it as dependant on the ignition table value at that RPM
/ Load is what the ignition timing is advanced to.
Its not so much the idling you need to worry about.
its the top end under boost.
thats what expires engines.
especially as it comes on boost.
ignition
/ fuel
/ air temp.
all factors.
"And how do I speed up the tick over, is this a manual jam the butterfly in a slightly open position jobby.
Nope, dont adjust the butterfly.
.as the idle control valve will try and compensate
( back to square one
If you've got a FC commander
Settings
> Enter
> Rev Speed
> Enter
Half way down, you'll see the idle values for idling with electrical load, idling with a/c and just plain ole idling.
Adjust the basic one initially
The power FC will go through a few minutes learning curve to settle the idle.
hth.
