Now I'm pretty handy with a socket set so I'm sure I can do this myself.
http://img11.imageshack.us/gal.php?g=picture008ciq.jpg
Images 2 and 7 are duplicates of the full kit 10 bushes in total each of which comes in 2 pieces and a slieve.
Now I've found out that image no 4 above is the front strut bush.
Image 8 is the 4 smaller bushes 2 have a narrow hole slieve 2 a slightly wider hole.
Image 6 is a mystery not even sure if its assembled correctly.
Also which bush are the washers for?
Any help would be appreciated
Tony
edit
found this list of what is included in the kit anyone know what is what?
SW20 full kit contents:
Front control arm bush x 2
Front strut bar bush x 2
Rear control arm bush x 2
Rear strut bar to chassis bush x 2
Rear strut bar to control arm bush x 2
All required inner sleeves and washers
ARB bushes fitted already
