One thing to bear in mind is if the previous owner only did short journeys, then there would be a fair amount of water mixed in the oil: when the level was checked, it would seem that it was up to the mark, despite the natural consumption of oil over time by the engine.
However, if you then do a long journey, then all that water
/ condensation, etc will be burned off: as a result it will look like the engine has suddenly lost a lot of oil.
All Mk1's, especially ones with aftermarket SS exhausts, suffer from steam coming out of the pipes when the engine is warming up: it looks alarming, but is merely the condensation inside the backbox evaporating.
Top it up and monitor it for a while: you can usually smell if you're burning oil, and the exhaust emits a bluish smoke rather than white steam.
Dont worry too much at this stage.
