I started to wire the headunit in the car today but there was no power so first point of call is to check the fuses. not really knowing where they are i look ed inside the fuse box on the nearside under the bonnet...and noticed a lot of stuff in there doesnt look right.
When looking at the fuse box cover, the FR FOG, RAD FAN and CDS FAN are all wrong. also is there meant to be something in the relays for FAN 2 and FAN 3???? i presume they are meant to be there?
The car the other day was running a little hot when stood still...is it because of missing fuses for the radiator fan?
and back to original question..where is the headunit fuse?
I believe the DOME fuse also runs the headunit.
As for the missing fuse, no harm in putting one in there.
The others I would replace at the same time especially the one with the wrong rating.
