thats great if the mk2 tb fits! does it line up with the 4age manifold correctly ie with the breather hole and that?
well its an ae101 loom when looking at the connectors on for the ecu.
but the guy i bought it off couldn't find the ecu so got one off a guy in aus for an ae92 as aparantly the knock map isnt so sensative which was an issue with the ae101 ecu.
anyhow looking at the ae92 to ae101 ecu i just need to swap 4 wires around to make it run as they changed them around for some reason or other.
im certain its a small port aswell as it has coil ignition and a map sensor so is either a late ae92 or ae101 but from the wiring im going with ae101.
until i get a wiring diagram which i bet is on one of the aus or nz forums i cant really look into triming the loom down for my needs.
the way i look at it as long as i has the cam sensor, map, lambda, inlet temp, tps and coolant temp sensors connected it hould run ok.
all the other valves and stuff are either emissons related for evap
(which the mr2 doesnt have) or for idle control but i have no pas, aircon etc as its a track car so should be manualy be able to set the idle speed and im not keep on the stupid high revving cold start so that can go.
but if the mk2 tb fits then it should idle spot on.
my only concern is the fact the sc has about a million vac hoses so sorting them out could be interesting.
oh and the fact the fpr seems to have a solenoid in its line so the ecu controls when it raises the fuel pressure which seems very odd to me.
but i have a wideband so can check the fueling out when its running and see if i can connect the fpr direct to the inlet manifold without it overfueling etc.
