Spot on jimi
I was just about to suggest the N1.
they get corroded pins in there too,the boot gets wet in the plug area.
Id also carry out a continuity test between the blue wire on the N1 and the fuel pump wire at the centre console.Also if you look at the N1 from the rear of the car it has a left and a right side.If you get someone to crank the engine while checking for power on the right side of the plug
(blue wire and plug not pulled apart),and it has power there,then its the N1 to blame or a wire break between the N1 and the pump.
If there is no power on the right side of the N1 then you have a COR issue
(circuit opening relay).This is located on the side of the ecu,a black relay with 5 pins on it.
To test the COR,unplug it,and check there is power on one of the terminals with ignition switched on,if there is make a note of this wire,you will need it in a minute.
If there is no power on any COR pin with ignition on check your fuses havent blown in the engine bay fusebox.
Once you have established there is power at the COR try bridging this pin with the blue wire on the same plug,if the pump starts running with the ignition on then the N1 is fine.
Now establish the COR is earthed,its a white/black wire.
do a continuity test to the chassis.
Next, one of the COR terminals is a starter feed,this energizes the COR during cranking.
so test that one pin becomes live when the engine is cranked.If it doesn't then you have a wire break between the COR and starter solenoid wire.
If that checks out and everything else seems in order the final wire to check is the Green/red on the COR,the ECU grounds this to keep the COR closed during running
(and keeps power at the pump).
try permenantly grounding the green/red
(with the COR plugged back in) and if that works then the G/R wire is broken between COR and ECU
,OR the ECU is faulty and is not earthing the COR.
Finally if all of the above checks out and every wire going to the COR is doing its job
,and the N1 is ok,and there is continuity between N1 and pump,and the pump earth wire itself is ok
(B/W) then you have a faulty COR.
Thats as much info as i can give on the subject,hope it helps.
