spent 30 mins tonight making sure the cooling system was properly bled but still popping.
thanks in advance
halflife
un1eash wrote:It may not be firing on all 4 and another way to check is to pull the spark leads off one by one with the engine running.If theres no change in the engine tone or running then you know that cylinder isnt firing right.
BIGBOBO wrote:Have had the same problem for ages.
Checked vacuum leaks, ignition timing, valves, compression,.
Replaced spark plugs, leads, distributor cap& rotor, cam belt, all filters,.
Finally noticed that the reistance on my ignition coil is out of spec(1.2 ohm where max 0,7 is allowed) so I bought a second hand coilpack on ebay.
Waiting for it to arrive, hope that'll fix it.
halflife wrote:Have you tried loosening off the dizzy and retarding the ignition a little?
halflife wrote:Update
Checked dizzy cap, rotor etc all seem fine(gave everything a good clean down anyway)
Tried mixture screw, made no difference so put back to where it was originally
Then started to fiddle with timing.If I retard timing sufficiently I can get rid of the popping but I loose power.
This has got me thinking.The car is fitted with a DTW tuned engine, one of the modifications
(an
£800 mod 7 years ago
) was to have the ECU rechipped and mapped.
I am wondering if it has been set up to run on only the expensive stuff
(98 RON).
Unfortunately
(and unusually) I have a full tank of the
'cheap'
stuff in there at the moment so it will be a while until I can find out.
crazybrightman wrote:i take it you have an uprated engine and ecu? if so then the ignition timing may need stting differently.timing it to stnadard spec maybe wrong.
how ever nearly all mr2's seem to miss slightly when free reving so i wouldn't worry about that too much.
if its been worked on alot internaly then they may have raised the c/r alot so high octane maybe required to stop knock but unlikely as they are quite a low c/r to start with.![]()
have you tried adjusting the idle screw on the tb to up the idle speed say 50rpm as that usualy helps no end.
