I had a lot of trouble with spongy brakes last year but eventually resolved them.
I checked the rear pads at one side before I changed the calipers
& they were perfect.
I assumed the other side were fine
& left them in place when doing the calipers at that side.
Turned out that the old calipers on one side had been binding
& the pads had been roasted
& gone off.
Changing the rear pads helped sort the problem.
I would put new pads all round
- they're cheap
A few things I did.
Not sure if they are of any use but here goes:
1.
Disconnect the handbrake at the calipers.
Screw pistons all the way in
& back out 180 degrees to line up with notch on pad.
2.
Started engine
& left running
( a mechanic told me this helps)
3.
Bled from furthest away first( rear passenger,the rear drivers side, then front passenger
& finally front drivers)
4.
Reconnect handbrake
& adjust
It took a while but worked for me
Tim
