Anyone got any other clutches they can recommend?
JJ wrote:Just an important additional note on uprated covers..
Need to be careful in your selection as it is quite common that if the cover is too strong( clutch manufactures will deny liability
) this will load up the thrust bearings on the engine
- this is the laterial forces on the crank
( especially cold starts with the clutch in
- you're pushing against the cover) this can prematurely wear or damage the thrust bearings and thus causing engine failure or over time, create some crank float.
I've built/ seen a Supra engine fail on thrusts bearings 4 times and blamed it on all sorts before pointing the finger at the clutch cover not being engine friendly
- Great bite on the friction plates.
but short lived engine and a whole lot of unecessary labour
So would that clutch you have spare cover 350bhp easily or is your current power around the mark i'm aiming for anyway?
Would the RPS one that can take 399fp torque
I'll pretend to understand all of that, nodding and agreeing
Tasty wrote:os gilken twin, good clutch but they rattle like f--k
, good at the lights though
, posers think that you`re driving a pile of sh-t
some say it is due to improper installation
Turbolad wrote:I've got that rps 6 puck on mine, had it getting on for 2 yrs, since then power has gone from 300- 340
- 400 now with 340 lb/ft and o far so good with the clutch
