One thing I'd like to know is, the lambda sensor
- do they go gradually? or is it either completely fine or completely broke?
Like widebands, I guess they can go out of calibration and send false readings back to the ecu.
which in turn will probably increase the mpg.
Widebands lifespans are debateable.
I've not seen one last longer than 2 years.
I've seen a few instances.
a change in the 02 sensor has resulted in an increased mpg.
.the error codes are only apparent on the heater element of the lambda
( apart from Rev 1/2 turbos
- no heater
Again.
taking into consideration the weather as well.
the EFi maps will stay on the warm up enrichment a little longer than in the summer
= increased fuel usage.
With the 3S block being of a cast iron construction, it does take considerably more time than full aluminium
/ alloy construction engine designs.
.Factors.
like flat tyres
/ brakes binding etc.
need to all be considered.
I had a friend with a Rev 3 turbo.
poor on the petrol
and these are renowned for being brilliant when you think of the performance they produce
( often Circa 300 miles to a tank
turned out that one of the front calipers and the rear calipers was binding on slightly.
might as well have been towing a caravan around with him.
For the price of a new lambda sensor.
it'll pay for itself in a few month
/ weeks if you're a daily driver.
with the increased milage you'll reward yourself with.
Nothing worse that tootling about and getting the same rubbish fuel consumption as if you'd been kicking it all over.
