mine had a bit of space underneath so it could clip in, but i ended up snapping off the top clips and using a bit of tape to make the surround stick in.
i've got one of the din pockets in the bottom slot.
as far as the wiring goes, mine's pretty similar, i have a sony mp3 headunit with only a pair of pre-outs.
these are connected directly to the autoleads wiring connector's front speakers, with the rear outputs coming from the speaker outputs on the stereo through a line level converter i picked up from halfords.
i did have to put some crimps onto the line level converter as one end was a pair of rca female, and t'other 4 wires.
the crimps slotted straight into the pins on the connector from the sony headunit so all is good.
Couple of points tho, there is a large difference in volume so the fader has to be set quite far to the rear to lower the rear speakers
(mine is also back-to-front).
I found that when it was plugged in correctly, i.e.
front output to front speakers, rear output to rear speakers, i got a horrible
*loud* squealing noise whenever the ignition was on, which i presume is related to the power steering pump, that i've seen mentioned many a time on here.
Switching the outputs around seemed to solve it, no idea why but i'm not one to tempt fate so it's good as it is.
Also i found that since the subs under the seat are connected to the rear outputs, changing the fade slightly is a good way to turn the bass up or down
![Smile :)](./images/smilies/icon_smile.gif)
