[Mk2] [NA] FE Automatic transmission
waelwulfas
Post by waelwulfas »
Hi Folks, well the little FE's reached 143,000 miles now and I'm suspecting the gearbox may be its financial death knell.
All is fine with the auto except when pulling away from standing. I get an appalling vibration/tramp and what sounds and feels like wheelspin. Once it gets going it picks up 2nd gear and runs fine. Any mechanics/specialists got ideas?
JJ
Re: [Mk2] [NA] FE Automatic transmission
Post by JJ »
wonder if it needs just a flush and change of tranny oil... ?? When was the last time you checked the level ?? colouration ?!
vinnyninja
Post by vinnyninja »
defo check the oil .....i had that problem its like the wheels are skipping like wheelspin but bouncing in 1st then went away when it picked up
id never had auto and thought if the oil was low i would get a light
WRONG
gearbox went blew the seals dumped auto fluid evrwere smoke 15 mph limping home
not good
waelwulfas
vinnyninja wrote:defo check the oil .....i had that problem its like the wheels are skipping like wheelspin but bouncing in 1st then went away when it picked up
WRONG
not good
Checked oil level, okay and quite clean
vinnyninja
not to sure then bud sounds like my symtoms at first
3S Service Centre
Post by 3S Service Centre »
Drop the gear oil and inspect for metal.
After that jack up the back of the car and rotate the wheels to indentify if its 1 sided or both, could be a cv joint you see.
James
