IMOC - winners of JAE best overall club stand 2010, 2013, 2014 & 2017! 1994 GT-S T-Bar 397bhp with NOS *sold* 2016 Porsche Cayman 981GTS 347bhp Flat Six
if its mapped by then i'll be up for this, just out of interest do they use a hub of wheel dyno and state power at them or the fly?
1 ) tiny - mk1
2 ) jaspa - mk1 1.5 turbo
3 ) bry - mk2 turbo
4 ) mel - mk2 turbo
5 ) omracing - mk1
6 ) mk1 turbocharged steve - mk1 1.5 turbo
7 ) nigel orton - mk1
8 ) pete kyte - mk1 sc
9 ) mistertwokw ? - mk1
10 ) bob howard - mk1
11 ) nedward - mk1
12 ) pistol pete - mk1
13 ) tarmac terrorist ? - mk2 turbo
14) CM1GT - mk2 na
They don't have the hub dynos where the wheels are removed & the hub is bolted. They measure wheel horse power & have a process that calculates transmission loss & hence engine power.
Red MR2 Mk1a - Rose SOLD
Blue MR2 SC conversion 180 bhp - Lightning
Bry wrote:Will they be checking our AFR and checking for DET ?
Apologises but what does that mean ?
Normaly a dyno operator will check if the car is running lean or rich by checking its AFR (Air Fuel Ratio) it's measured by inserting a wideband O2 sensor into the exhaust tail pipe. DET is detonation (a result of running the incorrect AFR or incorrect timing) basicaly DET will kill your engine. Any good dyno operator should not run a car on the dyno without checking the above as they risk doing damage to your car
Thanks I not that good with abraviations, but I will confirm with them.
I've checked with the rolling road and by the time we go there, they will have head phones that listen for detonation and they always use a gas analyzer to ensure the mixture is correct.
Tiny wrote:sounds good do they have a noise limit on the cars? ie if i rock up with an exhaust that has been measured at 127.9db
will they say no its too loud
No there's no noise limit, but remember to bring some earmuffs
As we are upto 16 cars, is it possible for the people that are definately coming, to PM me and arrange for a £10 deposit. As with everything I know some people will not be able to make it, plus a couple of the guys don't have a car ready yet.
We need at least 10 definate cars to make it viable for Revivals. Thanks
1 ) tiny - mk1
3 ) bry - mk2 turbo
4 ) mel - mk2 turbo
5 ) omracing - mk1
11 ) nedward - mk1
14 ) CM1GT - mk2 na
15 ) jimGTS - mk2 turbo
16 ) Moo - mk2 turbo
I have hightlighted the people who have already sent a deposit. There's no limit, but its probably a 10am start to 4pm or later. I'm was looking at about 12 cars, as each one will take 20 minutes to strap down etc. Can I add your name ?
