Its looking like I might have to change 5th gear. The clutch pedal is a little high aswell, so I'm likely to do both at the same time.
Any ideas on how much the parts are likely to be ?
Damn 5th gear !
Damn 5th gear !
Red MR2 Mk1a - Rose SOLD
Blue MR2 SC conversion 180 bhp - Lightning
Re: Damn 5th gear !
Admins can you please remove as this has been posted twice. Thanks
Re: Damn 5th gear !
It has been reported
I had an LSD put in (I bought the LSD seperately) and a gearbox reconditioned for £300, and that was a good price! So if your looking at a full box recon, about 300-400, it would be cheaper to get a good 2nd hand box and fit that.
There is a just 5th gear change you can do
http://www.mr2.net/trackdayqueen/fithgear.htm
As for clutch, std clutch from a motorfactor costs about £55-80 depending on who you know and if you get the smaller 1a clutch or the 1b (200mm, or the 212mm).
Re: Damn 5th gear !
omracing wrote:Admins can you please remove as this has been posted twice. Thanks
Done
Smallport 4AGTE
Re: Damn 5th gear !
There are 2 posts on the knowledge base on 5th gear cures, one from Lauren (Tims link above) and one from myself.
It depends how badly worn 5th gear itself is as to how much you'll need to replace but it can cost up to £200.
Re: Damn 5th gear !
i have a gearbox and can sort it all out for you. pm me or email crazylegskev@msn
Gearbox
Hi Kev ,
I've sent you a PM.
Scott.
I've sent you a PM.
Scott.
