Sorry if im sounding a bit of a noob but I heard from somewhere that uprating the cams can help reduce turbo lag? Is this true? And if so how much of a difference does it make?
Cheers.
mattcambs wrote:You could have Anti-lag setup on an aftermarket ECU.This changes the cam timing so that at low engine speeds the combustion exits the exhaust ports and keeps the turbo spinning.
It's what rally cars do.
It's not advisable in a road car
Century Motorsport wrote:mattcambs wrote:You could have Anti-lag setup on an aftermarket ECU.This changes the cam timing so that at low engine speeds the combustion exits the exhaust ports and keeps the turbo spinning.
Thats not correct, anti-lag infact alters the ign timing not the cam.It also requires an air valve on the manifold to bypass the throttle when its closed to enable the anti-lag to work.
And yes post chamber combustion will destroy a turbo pretty quick.
Nathan
jimGTS wrote:if you change gear at 5k, then there is no point at all in going for a big build when most large turbos are only fully spooled by 4-5k rpm..
jimGTS wrote:
i beleive i got 272 cams on, cam overlap is a pita in traffic, thats all ill say.
Hey jim,
whats sort of characteristics have you got??!
I run 272s with a 10.4mm lift.
and its quite steady at 1000
- 1100 rpm.
barr a little hunting that goes on sometimes
cantfindausername wrote:Some links showing ball bearings in turbos..
http://uk.youtube.com/watch?v=H1MryAt1dw8&NR=1
http://uk.youtube.com/watch?v=-Jkwt79Ax ... re=related
http://uk.youtube.com/watch?v=6YSDyI6sh ... re=related
http://uk.youtube.com/watch?v=E2ung98bu ... re=related
http://uk.youtube.com/watch?v=GZcJMRXR6 ... re=related
RyanRs wrote:If your car runs lumpy with 272s then its been set up poorly.
I do believe it was proven on the usa boards that Cams Do not cause bad tickover!!
its the use of very large injectors that does it.![]()
Imagine trying to fill a kitchen sink with a fire engine hose!? well thats the same principle as trying to hold a 800rpm tickover with 1600cc injectors.
About your turbo, if it spins for ages after you shut off the engine, then yes it is a BB turbo.
