hi all started instaling my charge cooler today, fitted the pre rad and ran the hoses. decided to put them into the frunk via the opening the heater hoses use then i am going to drill 2 20mm holes in the front panel and connect them to the prerad do you think it is ok to run the hoses through the frunk like this, i know it raises centre of gravity but think it will be ok, any opimoins people??
Hi,
I can't see the benefit of doing that? Have you mounted the pre rad in front of the stock rad? The feeds run under the car in depression under the transmission tunnel in the floor pan + the under trays fit over the top with minor cutting. There is room to fit everything out of the way almost like it was designed for it....
I'm doing some work on mine tomorrow if you need pics of where all the pipework is run in the front?? There are also some excelent "How Too" threads on this Seems a shame to start drilling and cutting metal work unless you absolutely have to!
No worries Ill take some tomorrow as I'm replacing the charge cooler pump. Out of interest what pump are you going to use? If its the stock celica one, I've found some pretty mental powdercoated brackets from B&Q that mount the pump up out of the way!
yeah got a stock one. Goin to do the bearings and mount it on the gearbox! These mounts ok for this? Any more info would be great m8! Got a rev2 and a st205 cooler. You kept the air con?
Yeah, I still got aircon, well my bracket snapped although its not exactly common I prob caught mine lol... I bought L'shaped brackets they're concrete-wood brackets in the roofing hardware section , I'll find the code/dims for you, they're about 4mm thick so no chance of them going!!
Here's a few pics i took today, I hope they kinda help, not the best I'm afraid...
Horns relocated to the LH side
Pre Rad in
Hot and cold pipes
RH side of rad
Pipes out of pre rad round bulkhead on passenger side / wheel well
As above but a bit furthar along
Uround the wheel well area, up and under the chassis
The tricky pit is routing round all the front suspension arms etc and into the trans' tunnel space without kinking the pipes.
Out the other end
As above
And a few of the pump/mount:
No worries, do yourself a favour and grab a bag of 5mm cable ties from B&Q they are re-useable white and its circa £5 for a bag of 50, they are strong as hell and will keep everything where it's supposed to be!
Man there's a lot of cable ties there! Is one pipe routed underneath the steering rack? Would be better to have it going over the top on the otherside of the car.
And where is the bleed? With pipes on the right hand side I'd have through the rad was the wrong way round? There's much better ways to run the pipes IMO.
I'll get some piccys of one I've just done I've got it down to an art!
I was about to say more or less what Luke just said, if that's a fiat rad then how do you bleed it? With the hoses on the passenger side of the car the bleed valve on the rad will be at the bottom which will make it more or less useless...
I'm not convinced your pump is up to the job either, as per Allan Welsh's findings... do you have any intake temp monitoring rigged up?
I started a guide for fitting the ST205 CC from the ground up but then someone drove into my car on the M1 so I never finished it. It might be of some use though, see http://www.imoc.co.uk/forums/viewtopic.php?t=103914
How do you mean? I had a celica pump which got damaged , this pump is from a chargecooler from a much much more modern car (clue it runs a VW engine ), agreed it looks very small but it flows a huge amount of fluid, you can see the flid moving hell of a quick through it!
The CC is stone cold even after long high boost pulls ie last night I did several full bore pulls through all the gears, pulled over, the turbo was glowing red hot but the coolant was cool when i put m finger in it.
I had to route the pipes that way round because my rad isn't stock and there wasn't room to get the pipes through in the normal way...
The temp sensor thing is a definate, I'm trying to build one at the moment using the KB guide
Oh and yes there are waaaaaay to man cable ties, I agree + didn't actually need hardly any BUT I'm a bit paranoid like that and went a little bit mad with them! They certanly aren't going anywhere!
Luke how do you normally rout the pipes dude? Be interested to see!
ahhh people I so have to get some pics of the last one I did! There's a few new tricks that aren't in circulation yet, but I've kept them to myself long enough! lol but you will have to wait for me to take pics. If you're really intrigued call me sometime!
