My previous REV3 Turbo used to do the same thing.
Does anyone else get this problem?
Just wondered if it is a common thing and wanted to ensure it is nothing to worry about.
going4the1 wrote:This fault CAN be resolved permanently without the removal of the gearbox or clutch replacement.
All that is required is to remove the rubber boot to gain access to the area surrounding the clutch release fork.see this link to get an idea of the internals of the gearbox housing:
http://www.turbomr2.com/MR2/HowTo/Engin ... GTE-08.htm
The area which needs lubricating is where the fork pivots on a pin(the cup on the fork is coloured green) This can be reached
- if you have long fingers.
Use a pea sized smear of CV Lithium grease
(the thick black stuff) on the tip of your finger and rub around the area of the pin.
Do NOT use WD40 or spray anything into the gearbox- it will not work.
WD40 will just wash away any remaining lubricant and the squeak will return in a few days.
I sorted my clutch 6 months ago and it has been silent ever since.
long fingers
