Just wondering if the rev3 has the same brake pads on the rear as the intial Mk2 from 1989 onwards.
Just got a set delivered here, Mintex MDB 1325 and wanted to make sure before I get the rear brakes all stripped off that they are the right ones.
Thanks folks and merry chrimbo
[Mk2] [Turbo] Rev3 - Are all rear brake pads the same size on mk2?
Re: [Mk2] [Turbo] Rev3 - Are all rear brake pads the same size on mk2?
IIRC the rev1/2 only had different sized front pads.
(the rears were the same size as rev3+ even though the rear caliper & disc is different - I think).
*edit, should have read...
IIRC the rev1 only had different sized front pads.
(the rears were the same size as rev2+ even though the rear caliper & disc is different - I think).
i thought rev 2 on were all the same ... time for peter gidden or rogue to step up with a definitive answer !
ALL mr2's,thats marque 1,2 or 3 all share the same rear pads.
splashnatz wrote:i thought rev 2 on were all the same ... time for peter gidden or rogue to step up with a definitive answer !
Sorry, yes, rev2+ all the same.
Sorry are we talking front or rear pads here? the OP asks about rears?
Sorry, my 2nd post was agreeing with splashnatz that the 'brakes' in general were the same rev2+
As I stated in my 1st post, rear pads are the same regardless of revision as you confirmed Paul
If the pads are the same does it then follow that the rev 1 rear caliphers can be used for the larger rev2 rev3 discs
keith030458 wrote:If the pads are the same does it then follow that the rev 1 rear caliphers can be used for the larger rev2 rev3 discs
Rev1 rear calipers have 16V stamped on them, rev2+ has 22V.
AFAIK this number is to do with the thickness of the disc that should be used with the caliper - so no, rev1 rear calipers can't be used with rev2+ discs.
