There appear to be multiple issues, which can be the problem, and I'll relate one that I just resolved.
Just to complicate things.
I had the same problem, more or less.
Car would not turn over, but I could hear a clicking sound from the rear.
All other electrical systems worked fine and there was no drain on the system when attempting to start the car.
I traced the clicking sound to the starter relay, inside the engine bay's main electrical panel.
I assumed since the relay was clicking, it must be engaging and therefore working properly.
Wrong!
The car does have just over 200k miles on it and I assumed it would not be out of the ordinary for the starter solenoid to be acting up about this time.
Other factors were that the car could easily be jump started and it could easily be bump started.
I understand that the starter relay completes the negative ground circuit, to the starter, so it seemed that the little extra voltage/amperage I was getting from jump starts must be working on the positive side of things and was therefore enough to induce the solenoid to work.
So I order a replacement starter, spend 3 hours replacing it, and of course it doesn't help.
![Brick wall ](*,)](./images/smilies/eusa_wall.gif)
It turns out I do have an extra starter relay I had forgotten about from an earlier model and decide to switch them, as of course it turns out that all AW11's use the same relay
(NA
& SC).
Well of course the car starts right up.
And for whatever reason it now starts a bit quicker than it has for some time.
It doesn't sound like it is turning over any faster, with the new starter, but hey, I'll take what I can get
(it just bothers me that the quicker starting is a bit unexplainable).
