All anoraks welcome to tell me what this is!!
Tony jinxy froude
Post by Tony jinxy froude »
As per the title, waiting for someone to broaden my knowledge with what the hell this is for :-k :mrgreen: :mrgreen:
http://cgi.ebay.com/ebaymotors/Toyota-M ... ccessories
MartG
Re: All anoraks welcome to tell me what this is!!
Post by MartG »
Fits in the instrument cowl, detects sunlight, and helps control the aircon - my SC has the hole for one but it is no longer fitted
un1eash
Post by un1eash »
Wonder what that hole was for on the SC.
soven
Post by soven »
anyone have a picture of it installed? I have it but its stuck on using hot glue to the panel.
PW@Woodsport
Post by PW@Woodsport »
It looks vaguely like a capslock key :oldtongue:
crazylegs
Post by crazylegs »
ooh ooh, wonder if i have one. where abouts does it go in the dash ?
could buy it just to keep and look at !! #-o =; :-s
MartG
Post by MartG »
crazylegs wrote: where abouts does it go in the dash ?
Front right corner of the cowl over the instrument panel
Nimbus
Post by Nimbus »
MartG wrote:Fits in the instrument cowl, detects sunlight, and helps control the aircon - my SC has the hole for one but it is no longer fitted
ahh, is that the hole on the right hand side, top of the cowling, towards the windscreen ?
I'd been wondering about that too... :roll:
mr2mk1chick
Post by mr2mk1chick »
I had one too...but now its burned with the rest of the SC :(
however, if you have the hole in the cover bit, most likely you will have the sensor but it may have dropped out. they only ever seemed to push into place. i found mine when removing the cover for something or other, so i held it in place with blutac
Nimbus
Post by Nimbus »
mr2mk1chick wrote:I had one too...but now its burned with the rest of the SC :(
hmm, a poke around needed then.. :)
tho it looks like a replacement 'grommit' has been fitted in its place already.
Mk1 Turbo Powered Steve
Post by Mk1 Turbo Powered Steve »
I have a plastic cap in that place, the sensor sits just underneath it.
I never knew what it was for until now 8) I don't have aircon in mine anymore but the sensor is still there.
mr2mk1chick
If it's a factory fitted looking cap or grommet then there may never have been a sensor.
what i meant was that if you had a hole there it could easily be that your sensor had fallen out and will be found underneath (like mine was).
Nimbus
Post by Nimbus »
Ahh got ya :)
yes it looks factory fit, so guess its never had one..
I had wondered if it had been some kind of 'boost' gauge stuck on the dash by a previous owner and since removed, but this seems far more likely :)
MartG
Post by MartG »
If the cap is translucent black, I think the sensor fits inside it i.e. the cap is a protective cover for the sensor
