No lights on dials or heater control!
STUAW11
Post by STUAW11 »
Noticed today that the instrument cluster and heater controls have blacked out :!: obviously a connection problem, but has anyone had this and is there a common place to check? before i start taking the dash apart
MR2MK1MAD
Re: No lights on dials or heater control!
Post by MR2MK1MAD »
Have you lost the rear sidelights and number plate lights
As i had a problem with losing the dash lights that i put down to a loose fuse.
Turned out to be the relay was on its way out
£10 for the auto electrian to check/find fault changed the rear fog light relay so i could drive in the dark
£20 for a new relay from the local toyota dealer
Relays are located above the fuse box in drivers footwell
Hope this is of some help before you have to take the dash apart
STUAW11
Post by STUAW11 »
Iv still got the tail lights, but the dash lights have started working intermitantly, sometimes if i knock the dash or just above the heater controls they come on again :? iv got plenty of spare relays so il try changing some on this circuit :!:
vix
Post by vix »
I've got the same problem Stu, let me know if you find a solution!
