WeirdNeville wrote:I was advised by a very competent mechanic to always use an engine flush each time the oil is changed.
I did so, and now I have a slight weep around the sump gasket so this will need to be changed in the future.Ho hum, I suppose I'd rather not have a gunked up engine!
crazybrightman wrote:ok problems with an oil slush and can move debris an cuase bloackages/damage.it can make seals leak but less likely these days.
crazylegs wrote:chris get some of that gasket seal stuff to bung in the oil( another additive
) probably wont do a thing
