Had a problem today.
went for a gear change and nothing- couldnt get it into gear at all.
Pulled over and checked a few things;
- plenty fluid in the master cylinder
- no fluid dripping down
- Gear shift cables still attached
- with the engine off i can engage/disengage all 5 gears like normal
I was able to get home in first gear by starting it in gear and then turning her off at junctions.
Basically the clutch doesnt seem to be disengaging.
What i will do next is get someone to press the pedal while i look to see if the slave cylinder is moving.
If its not the slave cylinder, any ideas whats happened? I thought perhaps the release bearing
(which has squeeked for ages) but i'm not sure??
